Ideal TT springs/coilovers
ive used a ton of different set ups and really i am a big fan of coilovers. I am a huge fan of Bilstein and eibach, in that order. H&R are good too but they only make springs and use bilstein shocks.
what is the advantage of using coilovers vs just buying the struts and the springs seperately? and what makes Bilstein better than Eibach? I ask because it's about time I change my shocks, since I can feel all the potholes on my drive to work [&:]
I've been looking at the 2 on some websites, and both allow the car to be lowered -- so if I was to lower it, what else would I need to do to make sure the car is 100% stable?
Anyone know what the difference is between the Bilstein PSS9 and PSS setups? The PSS9 says it comes with damping adjustments...but I don't know what that is.
Someone said that putting performance springs on stock struts will tear them up in a hurry. How can you tell visually that the damage has occurred? More specifically, when I do go to replace my shocks, what should I look for to see how bad the damage is for maybe not staying up on replacing them? I haven't had the car for awhile, so there's no telling how long it has been.
Sorry for just asking away like this, but it's all new to me, so I gotta start somewhere
Spring/Shock combinations are the cheaper route. They do allow lowering, but it is usually by a fixed amount. Coilovers on the other hand, give you adjustability in ride height and depending upon what type you buy you also gain dampening and/or rebound adjustment. Coilovers also allow you to easily corner balance the car to improve stability and handling. There is no difference in labor between the two options and you are usually looking at around $400-1000 difference on parts (depending on which options you choose for coilovers).
I went with Koni Sport coilovers on mine. I did all of the installation myself but took it to a performance shop for the corner balance and alignment.
I think I remember reading for the Eibach coilovers that they allow the car to be lowered up to 3" (but I could be remembering wrong). So say I got em, and did lower it that much. You can't just do that without messing something up can you? Is there something else I would have to buy to make sure I didn't cause any problems to the tires or the alignment or anything else I don't know to think of?
You would probably need camber plates, and an aftermarket front swaybar to re-establish alignment and maintain suspension travel clearance. I dont see how it would be driveable on the street w/ a 3" drop though. 1.7-2" would be pretty much the limit for street driving and an acceptable ground clearance and would still be REALLY low, maybe still impedeing wheel travel.
Anything over an inch and you need aftermarket parts to keep it in spec and safe.
ORIGINAL: Mikefc626
I've got about 2" of drop and used a full KMAC on the rear. Keep in mind, that even if you use the Forge arms, you'll most likely still need a 1/2 KMAC on the upper arms to gain enough adjustability to correct toe. The fronts for the most part have enough in the stock setup to get alignment back to spec without anything special. Although you can go to a Ground Control kit to get full adjustability in front, but it isn't really necessary unless you get really radical.
Perfect Wheel Gap
XLR8: What size wheel/tire combo is that? And whats the offset of those wheels? That stance looks Great!
ORIGINAL: DenimTT
Perfect Wheel Gap
Perfect Wheel Gap
I am running 18x8.5 ET38 with 25mm spacers front and rear.
ORIGINAL: Mikefc626
