im having trouble with the windows
Old Sep 25, 2007 | 02:29 AM
proxeyed's Avatar
Default RE: im having trouble with the windows
So does anybody have, or fixed this type of problem? Im pretty sure its just a window trim deficiency, but just curious on where to get some. Ill try googling this again, but I don't think I had good luck with it. ANy help would be appreciated.
Old Sep 25, 2007 | 10:46 PM
listentodabeat's Avatar
I just posted about the same problem proxeyed. My window does the same thing, goes up, then back down, i have to tap it little by little till its all the way up, pissin me off.
Old Sep 25, 2007 | 11:11 PM
ouTTie914's Avatar
proxeyed: Make sure the rubber trim at the top of the window is place, and not tucked into the seam.
Kyle: Hold the window switch down, then tap it down once. Should fix the problem it's pretty common, and this just resets the window.
Old Sep 25, 2007 | 11:26 PM
Yanaki's Avatar
Im having the same problem as Proxeyed. What is exactly the windows reset trick?. How to do it?? Will that cure the problem permanently? Its pretty anoying.
Yanaki.-
Old Sep 25, 2007 | 11:35 PM
cincyTT's Avatar
I'm make believe
^ hhhhhhmmmmmmmmmmmmmmmmmmmmmmmmmmmm
ORIGINAL: ouTTie914
Old Sep 25, 2007 | 11:39 PM
Ya know, Becca, we're going to get along jussst fine :] another problem solved !
Old Sep 26, 2007 | 02:36 PM
So.. I spoke too soon, i get a half hour from my house and i couldn't get the window back up for 20 mins, it ended up stopping like half way down and acting like the window was rolled all the way up, i tried rolling it all the way down and then holding the button but that didnt do anything. There had to have been this problem with the car for a while I was testing the TT out earlier and when i hit about 110 the wind noise from the drivers side window was horrible, i'm going to just take it in and get it fixed and over with.
Old Sep 26, 2007 | 07:41 PM
  #18
myrodhTT's Avatar
my problem is that the window goes up but not all the way up and i have to get out of the car and us the key to get it to go up all the way all i have to do is the window reset correct
Old Sep 26, 2007 | 08:05 PM
  #19
USAF29's Avatar
LOL!!! My drivers side window does the same thing...and when i wash my car, water ALWAYS seems to make its way inside...i need to fix that before the rains come....
BTW...how do you do the reset??
Old Sep 26, 2007 | 08:50 PM
  #20
proxeyed's Avatar
Reset by holding the window switches up or down until windows are all the way up or down. then let go, and hold for another second or two in the same direction. You will here a little click. A reset only lasts as long as my car is running, the next time I start it up the same problems. When I lock my car by key and not fob, It does the same thing. When I lock/ unlock it from the passenger door, its backwards.. Counter clockwise locks the car, and clock wise unlocks it. Ugh! listentodabeat let me know what your dealer says. For the window trim, everything is tucked in and in the right place.
Oh well, atleast this is all overshadowed by a suspension that sounds like the door to a haunted house, still gotta get that fu**ing thing fixed.
