ing to add a intake to my 2002So many intakes?
Old Jan 23, 2007 | 06:37 PM
MasswholeTT's Avatar
Default ing to add a intake to my 2002So many intakes?
Im looking to add a intake to my 2002 180 TT There are about 4000000 diffrent intakes out there which one should I gowith? I want to get the best bang for my buck for sure....Thanks!!!
Old Jan 23, 2007 | 06:46 PM
bmwtoaudi's Avatar
Default RE: ing to add a intake to my 2002So many intakes?
MODSHACK
Old Jan 23, 2007 | 07:14 PM
cincyTT's Avatar
I'm make believe
larger intake filter on the maf. cost under a hundred dollars and if you add a funnel on the inside will flow very nice. Plus get a oiless filter if you can. To much oil on the filter can cause cel for a bad maf and require more maintaince.
Old Jan 23, 2007 | 08:12 PM
Im not fimiluar with MAF? do you have a link to the company?
Old Jan 23, 2007 | 09:19 PM
Inimical's Avatar
The MAF is the Mass Air Flow sensor, it's what most aftermarket intakes connect to.
Personally, I dropped $45 on a K&N panel filter that basically just replaces the stock filter, since the intake setup in the TT is actually pretty good. SUPER easy install (just replace the filter)
I noticed a difference right away and it didn't cost me too much $$.
Highly recommend K&N.
Old Jan 24, 2007 | 11:17 AM
stephenson27's Avatar
I've ordered a K&N so I'll be adding it this weekend but will also be cutting the bottom of the stock box out to allow a little more air flow. Due to the thickness of the stock box it works as a heat shield of sorts (better than throwing in a cone by itself). A buddy of mine with a TT here in town did that and then "upgraded" to a cone and said that when he "upgraded" he couldn't really tell a difference. We shall see...
Old Jan 24, 2007 | 02:16 PM
225tt's Avatar
www.modshack.info
Old Jan 24, 2007 | 02:20 PM
NeXeA500's Avatar
where did you get the k&n drop in filter? Also, isnt that an oiled filter? I know the k&n cones are oiled, how about the dropins?
Old Jan 24, 2007 | 02:46 PM
225tt's Avatar
Yes they are.
Old Jan 24, 2007 | 04:05 PM
To my knowledge all K&N's and any "lifetime" filter requires to be oiled. You just have to contain yourself and not drown it so to not kill your sensor. I ordered mine from ecstuning. They're about 5-10 bucks cheaper than other places I found and I was ordering from there anyways.
