Input needed
Once out of every 10-12 times i start my car it will start like normal and as the engine comes back down to idle instead of stopping at ~700 rpms and idling it will just drop and die. So after i restart it and give it a little gas it is fine and comes down to idle normally
I had about a quart of oil in my intercoolers and once they pulled it out I had no more issues. They never pulled it out from the blown turbo. Take a look in the hos that connects your IC to your turbo. If there is black oil residue you found your issue.
Iam not 100%sure but I thind that Cincy means an AIR leak (boost or vac) you should get a boost gauge! as he would say.I had a similar problem and I just replace a cracked plastic hose in a engine bay.
