Input needed
Old Jun 12, 2008 | 10:18 PM
Warhawk's Avatar
Default Input needed
Once out of every 10-12 times i start my car it will start like normal and as the engine comes back down to idle instead of stopping at ~700 rpms and idling it will just drop and die. So after i restart it and give it a little gas it is fine and comes down to idle normally
Old Jun 12, 2008 | 10:38 PM
cincyTT's Avatar
I'm make believe
Default RE: Input needed
could be a vac leak or to much fuel, any mods?
Old Jun 12, 2008 | 11:28 PM
Warhawk's Avatar
No mods as of yet, it isnt leaking any fluids under the car at all. It runs perfectly fine 100% as soon as it is started
Old Jun 13, 2008 | 03:25 PM
Warhawk's Avatar
so any other ideas?
Old Jun 13, 2008 | 03:26 PM
cincyTT's Avatar
I'm make believe
have you even looked for a vac leak?
Old Jun 13, 2008 | 04:32 PM
Mac_17's Avatar
I had about a quart of oil in my intercoolers and once they pulled it out I had no more issues. They never pulled it out from the blown turbo. Take a look in the hos that connects your IC to your turbo. If there is black oil residue you found your issue.
Old Jun 14, 2008 | 02:01 PM
Warhawk's Avatar
What is the best way to check for vac leaks and where are the most common places?
Old Jun 14, 2008 | 07:47 PM
theTTkid's Avatar
i had the same problem... turned out to be crankshaft positioning sensor
Old Jun 14, 2008 | 07:58 PM
pitrman's Avatar
Iam not 100%sure but I thind that Cincy means an AIR leak (boost or vac) you should get a boost gauge! as he would say.I had a similar problem and I just replace a cracked plastic hose in a engine bay.
Old Jun 14, 2008 | 08:05 PM
Warhawk's Avatar
would a vac leak cause the CEL light to come on? Ive got no lights or indicators at all
