Installed a chrome intake but engine heats up... ne one know y?
Old Jul 16, 2007 | 12:24 AM
LovemyAudi's Avatar
Default Installed a chrome intake but engine heats up... ne one know y?
I bought this chrome intake on ebay but found out that it was some cheap filter, which i expected, but still had hopes.. I bought it because i live in the houston area where it floods alot so I dont want a cold air and brands like carbonio are too expensive...Anyways I bought a AEM dry-flow filter to replace the chrome intake. For some reason my engine keeps lagging and the coolant temperature goes to H, especially when i have my engine on at rest or slow moving (such as traffic)... alot of people told me the intake was taking in hot air so i should get a heat shield for my intake.... does anyone know where I can get one or if it is even necessary? (btw I also just replaced the coolant hoses and checked if there were any leaks anywhere in the coolant) .... anyone? cincy?
Old Jul 16, 2007 | 12:36 AM
cincyTT's Avatar
I'm make believe
Default RE: Installed a chrome intake but engine heats up... ne one know y?
no intake. no matter how hot of air it takes it, will increase the coolent temp. You either are getting low on coolent, need a new temp sensor (if you have a black one, you should get a new green one), or have a fan problem. The first two are the more likely causes.
when you say your engine is "lagging" you mean its jerking, bucking and not making power?
Old Jul 16, 2007 | 12:37 AM
LovemyAudi's Avatar
when i mean lagging it isnt making enough power... when the indicator is in the middle you can feel a push but when its near the H it takes a long time to accelerate
Old Jul 16, 2007 | 12:58 AM
cincyTT's Avatar
I'm make believe
for starters, i hope you didnt install an intake and hoped for big noticable gains. But it seems like you have a cooling issue you need to resolve. The power is most likely "lost" because the engine is operating at a higher temp than it should be. So i would start with the things listed above. I can tell you that my car's temp would creep to the next line past virticle when my coolent was low, and not low enough to get a low level indicator.
Old Jul 16, 2007 | 01:07 AM
225tt's Avatar
Does the intake connect to the turbo or just the intake hose?
Old Jul 16, 2007 | 02:12 AM
qwert's Avatar
yea my car starts to overheat while im idle in traffic ppl tell me it might be the thermostat and aside from that my ac wasnt blowing cold air so i thought it was the freon and when we tested it..it had plenty of it but to much pressure and they said its keeping the compressor from starting so i have the overheating issue and the ac thingy to deal with(hoping i dont need a new compressor) and i live in dallas so yea i be burnin up
Old Jul 16, 2007 | 04:30 AM
LovemyAudi's Avatar
ORIGINAL: 225tt
The intake hose .. i just took out the stock air filter box and I replaced it with the new intake
Old Jul 16, 2007 | 04:32 AM
LovemyAudi's Avatar
ORIGINAL: qwert
yea texas kills my car - - ;; im also having the same problem too ... the ac isnt blowing cold air either im going to ask the mechanic that i kno and i will post something if i get ne thing
Oh and I didn tadd the intake for much gain but just one of things that I wanted to start out with. I just started modding and that was the first thing that popped into my mind ...
ATL Guy
Aug 16, 2012 10:17 AM
musiclman
Mar 25, 2008 08:43 PM
crayzdavy
Nov 5, 2007 02:38 PM
KarlMarx
Mar 28, 2006 06:54 PM
Jenny
Jul 30, 2005 03:13 PM
