instrument cluster resets
Old Aug 2, 2008 | 10:51 AM
fireman9585's Avatar
Default instrument cluster resets
About half the time I start the car, the date and time and the trip odometer have reset, the clock to 12:00 and the trip odometer to 0.0. 2001 225 tt coupe. Help!
Old Aug 2, 2008 | 12:54 PM
ouTTie914's Avatar
Check your battery. Make sure the + and - cables are tight.
If you disconnect the battery make sure you have the radio code; just incase...
Old Aug 29, 2008 | 01:59 PM
Battery seems okay. Anything else that could cause this problem? I just got my cluster replaced under the settlement agreement and I hoped this would solve the problem. It did not.
Old Aug 29, 2008 | 03:04 PM
randomloginname's Avatar
Do you have code for short to/ interminttent ground? Mine kept doing that then I realized my negative terminal cable somehow worked itself stupid loose haha
Old Aug 29, 2008 | 04:26 PM
beachchair's Avatar
^^ All good points. Resetting itself probably due to simple electrical connection issue. If you can't find it, take it back to whoever installed your new cluster.
zombi4u
B7 Models
Dec 20, 2010 09:41 AM
jwelyczkowski
Jul 12, 2010 02:45 PM
asutherland
Jan 22, 2010 09:58 AM
charliea_62
Nov 14, 2006 03:17 PM
keko2004
Nov 2, 2006 10:41 PM
