Intake "flutter" noise ??
Old Dec 20, 2006 | 02:14 PM
azaky's Avatar
Default Intake "flutter" noise ??
Hey Guys,
I have a Evo Motorsports V;Flow intake and it sounds and works great when you mash on the pedal, but one question I have is that I hear a "flutter" noise when I let go of the gas and in between acceleration. Is that just the venturi working or is that not normal?
Any ideas?
Thanks in advance.
Old Dec 20, 2006 | 03:47 PM
cincyTT's Avatar
I'm make believe
Default RE: Intake "flutter" noise ??
your dv valve is more audioable now and if its fluttering instead of one quick release, your dv is on the way out. What are your other mods to make sure?
Old Dec 20, 2006 | 04:32 PM
225tt's Avatar
Grab yourself a new DV that should clear everything up
Old Dec 21, 2006 | 12:32 AM
azaky's Avatar
i put in a new Hyperboost dv right before I did the intake.
Old Dec 21, 2006 | 01:21 AM
cincyTT's Avatar
I'm make believe
add more tension to the spring/diaphram. either change to a stifferspring, add washers, tighten the diaphram, pending on which hyperboost you have.
Old Dec 21, 2006 | 04:15 AM
225tt's Avatar
I'm not saying that you hooked it up backwards, but I have heard of people doing that, just make sure you check your hoses.
Old Dec 21, 2006 | 12:01 PM
azaky's Avatar
I have the hyperboost HXc, can you even put stiffer springs in that thing? And I am pretty sure I hooked the thing up right, you really can't hook it up backwards can you, but I will check
Old Dec 21, 2006 | 01:58 PM
225tt's Avatar
Maybe that is just how that type of DV is supposed to sound, dunno maybe email the company but its deffinatly your DV.
Old Dec 21, 2006 | 02:57 PM
cincyTT's Avatar
I'm make believe
If the dv is making rapid spitting sounds the internals need to be tighter. the hx compact is a piston dv. pull the vacuum hose and twist off the top (careful, spring under pressure) and add acouple of washers. This should solve your problem.
boost777
Sep 4, 2013 12:56 PM
irishaudi
Aug 6, 2012 08:38 PM
SB Ridge
B7 Models
Oct 30, 2008 05:42 AM
jack1.8t
Feb 21, 2007 07:40 AM
GeoRay16
Oct 19, 2006 02:40 AM
