intermitant door locking
Old 08-17-2010, 10:14 PM
paulhtobiason's Avatar
Default intermitant door locking
My TT will lock without warning. So I always have my keys with. The feature that opens the windows from the outside with the turn of a key doesn't work. The chimes for key in ignition and lights on also doesn't work. Diagnosis says left side door latch. Hopefully warrenty will cover, if not it is about a $350 item including diagnosis!
P. Tobiason
Old 08-25-2010, 12:10 PM
quaTTrophobia's Avatar
take the left door card off (get a Bentley manual or some pix on the net) careful when removing the button on the door handle (inside). There is a small switch at the door latch which is acessable when removing the latch. Plastic switch usually brakes. Fix with a leaf style microswitch $4 at the electronics supply, and drill new holes for mounting.
While U have it open, remove the windo motor and lube the plastic m. and f.m. gears (motor and gearbox ) as well as cables with white grease.
a3turrell
06-04-2023 11:15 PM
pjaudi
07-22-2013 09:07 AM
dmw319
05-20-2010 02:20 PM
dmpp
08-19-2006 02:03 PM
goaliedave
12-04-2005 10:40 AM
Quick Reply: intermitant door locking
