International Octane ratings
Old Apr 8, 2007 | 12:12 PM
neur0tic's Avatar
Default International Octane ratings
Over here in Korea, gas is ridiculous. Its like â‚©1,750 per liter. Thats equivalent to roughly $2.00/liter or $8.00 per gallon. I noticed that the gas here comes in different Octanes as it does in the states (92, 95, 98). Now I have the APR 93 OCT chip. When I called APR to arrange them to flash the ECU on site, I asked about this and they told me that the Octane is just measured differently and that it was still 87, 89, and 93. I have a feeling the guy was pulling it out of his *** when he told me though. Anyone here know if there's some form of "Metric" octane measuring? I will use either the 95 or 98 in my car until I find out and probably upgrade to the 100 Oct race program if it turns out to be a real 98 Octane fuel they have here. any thoughts?
By the way, that is the price of gas on the Korean economy. I get my fuel on the military installations and only pay $2.68/Gal.
Old Apr 8, 2007 | 02:04 PM
ouTTie914's Avatar
Default RE: International Octane ratings
Since I was unsure of different octane ratings as well I checked out wikipedia... Hope this helps!
Measurement methods
The most common type of octane rating worldwide is the Research Octane Number (RON). RON is determined by running the fuel through a specific test engine with a variable compression ratio under controlled conditions, and comparing these results with those for mixtures of isooctane and n-heptane.
There is another type of octane rating, called Motor Octane Number (MON) or the aviation lean octane rating, which is a better measure of how the fuel behaves when under load. MON testing uses a similar test engine to that used in RON testing, but with a preheated fuel mixture, a higher engine speed, and variable ignition timing to further stress the fuel's knock resistance. Depending on the composition of the fuel, the MON of a modern gasoline will be about 8 to 10 points lower than the RON. Normally fuel specifications require both a minimum RON and a minimum MON.
In most countries (including all of Europe and Australia) the "headline" octane that would be shown on the pump is the RON, but in the United States and some other countries the headline number is the average of the RON and the MON, sometimes called the Anti-Knock Index (AKI), Road Octane Number (RdON), Pump Octane Number (PON), or (R+M)/2. Because of the 8 to 10 point difference noted above, this means that the octane in the United States will be about 4 to 5 points lower than the same fuel elsewhere: 87 octane fuel, the "regular" gasoline in the US and Canada, would be 91-92 in Europe. However most European pumps deliver 95 (RON) as "regular", equivalent to 90-91 US (R+M)/2,and even deliver 98. (ron)
The octane rating may also be a "trade name", with the actual figure being higher than the nominal rating.[citation needed]
It is possible for a fuel to have a RON greater than 100, because isooctane is not the most knock-resistant substance available. Racing fuels, straight ethanol, Avgas and liquified petroleum gas (LPG) typically have octane ratings of 110 or significantly higher - ethanol's RON is 129 (MON 102, AKI 116). Typical "octane booster" additives include tetra-ethyl lead and toluene. Tetra-ethyl lead is easily decomposed to its component radicals, which react with the radicals from the fuel and oxygen that would start the combustion, thereby delaying ignition. This is why leaded gasoline has a higher octane rating than unleaded.
Old Apr 8, 2007 | 02:28 PM
neur0tic's Avatar
wonder which one they use here
Old Apr 8, 2007 | 03:20 PM
XCLR8TT's Avatar
My guess is that you have the same basic three grades there as here, even if they don't show the same octane rating. Just fill up with the most expensive grade, empty your wallet and drive away.
Old Apr 8, 2007 | 03:30 PM
achTTung's Avatar
id expect to say which rating system they use right on the pump, but i would guess its the RON rating
Old Apr 8, 2007 | 09:11 PM
neur0tic's Avatar
It very well me be written on the pump. However, it will be written in "Tetris"
Old Apr 8, 2007 | 11:02 PM
ouTTie914's Avatar
Find a local to translate it for you? *shrugs*
Old Apr 9, 2007 | 03:51 PM
Vorais's Avatar
Actually he wasn't pulling it out of his ***. Korea (both North and South), Japan, China, and most other countries use the RON system. Octane rating of 98 is approximately equal to the 92-93 octane rating here in the US. Use the 98 octane stuff and have fun.
Old Apr 10, 2007 | 01:02 AM
neur0tic's Avatar
Thanks for the info. I'll go with the 98.
2000a4quattro
Mar 2, 2014 04:17 PM
Subzero
Feb 15, 2007 11:25 PM
CRAZYHAWK
Feb 22, 2005 11:06 AM
CRAZYHAWK
Dealerships
Aug 24, 2004 08:01 PM
Mykdiver
Aug 22, 2004 10:36 AM
