KO4 upgrade/compression rate
Old Oct 25, 2007 | 06:29 PM
outinfront's Avatar
Default KO4 upgrade/compression rate
I have my 225tt..i just heard someone with a 180 say that if he just slaps a ko4 on with all the necessary other minor stuff, that he'll have MORE than 225hp because of the compression rate on the 180 which is 9:5:1 compared to 225 which is 8:8:1. I think this is madness..is he right?
Old Oct 25, 2007 | 06:53 PM
cincyTT's Avatar
I'm make believe
Default RE: KO4 upgrade/compression rate
Yes, the 180 with 9.5:1 will have a small amount more power throught due to the increase in compression.
225 is 9:1.
**Edit, its was probablyme that said it, but that was a long time ago
Old Oct 25, 2007 | 06:56 PM
diehlryan's Avatar
w/ or without a SW remap?
Old Oct 25, 2007 | 06:57 PM
cincyTT's Avatar
I'm make believe
Same tune and psi.. ect.
Old Oct 25, 2007 | 07:03 PM
outinfront's Avatar
Yeah this guy says it'll have a hair shy of 20 hp over the 225..my bad on the 8:1 compression
diehlryan's Avatar
So in reality if my KO3s goes and I dont have the $$ for a BT upgrade.. I should get a bolt on KO4 rather than another KO3s?
Old Oct 25, 2007 | 07:07 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: outinfront
it would most likely be less than 20hp. But the 1.8T VW's make a good amount of power more w/ the ko4-20 than whati have seen the 225's dyno even with the extra powerloss
Ryan, you still need the 225 manifold and some parts from pro-imports to make it work.
Old Oct 25, 2007 | 07:40 PM
outinfront's Avatar
Oh yeah he said HIS was the k04/23 not the k04/20...I hate to kick the sh%$ out of a fellowTTer, but I didn't like his attitude
Old Oct 25, 2007 | 08:05 PM
quattro411's Avatar
to do the proper "225 k04" upgrade you need a decent amount of things
k04-020 turbo
225 exhaust manifold
225 injectors
dual smic or fmic (not sure if the single smic would be enough for the k04)
re-map
i'm sure there might be more, this is just what I have gathered in picking up info here and there
who has actually seen a tt that has done the "225 k04" upgrade?
Old Oct 25, 2007 | 10:07 PM
DurTTy's Avatar
ORIGINAL: diehlryan
i know im kinda drunk ... just went went bowling with 10 other co-workers had a 1200$ bill on company money = a lot of beer.... but wy go K03S or even K04-001 .. waste of cash,.... go BT
dont mind me. just rambling after 12 beers
