koni shocks owners?
Old Mar 23, 2008 | 09:20 PM
hotgrass's Avatar
Default koni shocks owners?
the koni struts comes in compressed i believe, how do you decompress them? do you just pull them apart and then install them? i could pull them and compress them again, is that normal?[/align]
Old Mar 24, 2008 | 02:13 AM
ouTTie914's Avatar
Default RE: koni shocks owners?
I worked on a lift so decompressingmy Koni sportswasn't an issue.
I can tell you that Koni sports are hydraulic,instead of being gas infalted.
So it's notthe typical once you cut theribbon you're screwed sorta deal.
Old Mar 24, 2008 | 03:06 AM
hotgrass's Avatar
i just installed it, i didnt do anything else. im not sure what else should be done
Old Mar 24, 2008 | 10:44 AM
themysteryman83's Avatar
The shocks are really easy. Two bolts and one comes out. With the Koni yellows, they are hydraulic like Becca said so you can just push and pull them in as needed.
Old Mar 24, 2008 | 12:17 PM
hotgrass's Avatar
are you guys serious i just stretched the shocks for the rear to reach the two ends of the bolts, it acts like the oem shocks but it doesnt expand back like the oem. tell me what am i missing? right out of the box, i installed it like it is bolt on.
Old Mar 24, 2008 | 01:08 PM
ORIGINAL: hotgrass
What do you mean it doesn't expand back like oem? Are you talking about the front ones or the back ones? The koni's are adjustable for the TT. It should have come with some instructions. They are a pain adjust fyi.
Old Mar 24, 2008 | 03:13 PM
ouTTie914's Avatar
Rear shock adjustment procedure. http://www.konina.com/comp.cfm
Old Mar 25, 2008 | 02:26 PM
hotgrass's Avatar
page not found
Old Mar 25, 2008 | 02:32 PM
http://www.koni-na.com/comp.cfmshe forgot the hyphen :-)
Old Mar 25, 2008 | 10:57 PM
ouTTie914's Avatar
Woops! Sorry about that! Thanks for having my back mysteryman!
