large oil filter = lower mpg???
Old Feb 27, 2007 | 02:20 PM
Mikefc626's Avatar
Default large oil filter = lower mpg???
last time i changed both my cars oil and filters, i used the larger Mann (?)filter from ecstuning and now both engines have slightly decreased gas mileage (1 - 1.5 mpg). is this normal? am i trading mpg for engine longevity? thnks
Old Feb 27, 2007 | 02:24 PM
cincyTT's Avatar
I'm make believe
Default RE: large oil filter = lower mpg???
how can you really claim/worry about a 1 mpg? You could just of beenin boost longer, more stop and go driving and so many other variables. I think this is more in your mind. But you do need to give your car a few more min. to warm up the increased amount of oil also.
Old Feb 27, 2007 | 02:29 PM
Mikefc626's Avatar
i didn't really care too much about it in the tt, but my wife had asked me "why is my car not going as far as it used to" for her beetle.
i didn't have an answer other than it was probably something to do w/ the filter, because she noticed it after the change.
just asking man.......
Old Feb 27, 2007 | 02:32 PM
cincyTT's Avatar
I'm make believe
theres just tons of variables. Thats all im saying.
Old Feb 27, 2007 | 02:39 PM
techbod's Avatar
driving against the wind/ window open / 2 passengers and golf clubs / your lasses handbagthe list is endless
Old Feb 27, 2007 | 06:16 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: avant80@2.6
your lasses handbag
Now thats streching it, lol
Old Feb 27, 2007 | 06:22 PM
proxeyed's Avatar
I changed the oil about a month ago in my car, and put a larger filter on. I've been noticing a small decrease in MPG, maybe a fiften mile drop on an overall tank. I never really linked the two together though, because I've been pushing a little harder on the pedal.
Old Feb 28, 2007 | 12:46 AM
aussiett's Avatar
I cannot really see why a higher volume Oil Filter would have any effect on MPG. If the different filter was more restrictive (a bigger filter is likely to be less restrictive due to a great filter area) then the oil pressure would increase but should not cause increased drag on the motor and if bad enough would bleed through the pressure relief value..
I suspect you may have changed your grade of oil. Using a heavier grade can increase fuel use. Either that or the environmental (driver) or climatic conditions are having an influence.
MikeSpock/AWE
Apr 17, 2015 04:28 PM
A4 Jed
Jun 23, 2013 06:13 PM
rawdney88
Jun 26, 2012 08:56 AM
cruciform
Oct 11, 2010 03:54 PM
wolfe2118
Jun 25, 2008 07:09 PM
