Light Icon?
Anyone know what this light icon means? Looked in the manual and all it says it that it may be the outside lights... those all seem to be working fine... annoying beep happens everytime i come to a stop and the light icon comes on?
Sensor maybe, dont think it would be a fuse...
Thank you for any thoughts...
That only pops up on mine when an HID goes out. I tried using aftermarket HIDs to change the color and went through about 5 different brands and colors and ended up going back to osram bulbs. Not sure why but after running aftermarket HIDs for about a week or so one or the other would start shutting off after hitting bumps. I guess its too picky. Changed them and no problem since.
I had that happening on mine and I never changed anything, I read in another forum of someone who was having a problem with back light (which mine was) kept sporadically going off and on. Took it to the dealer and they replaced the socket which was showing signs of marring. So I did the same and it happened to be the same thing ...the socket had some burning happening so they replaced without question ...it may be an issue that has not been assigned a TSB, or maybe there is one....... all I know is u might want to check your socket first.
