looking for a DV link
Old Feb 18, 2008 | 08:28 AM
taifighter's Avatar
Default looking for a DV link
I've been searching for a thread with recommendations for adjusting the Forge Splitterfor a chipped car. I can't seem to find any. Can somebody link me, or post up the adjustment recommendations? BTW, I have the Unitronics Stage1+ program.
Thanks.
Old Feb 18, 2008 | 12:53 PM
cincyTT's Avatar
I'm make believe
Default RE: looking for a DV link
Just keep tightening it until you hold the peak boost with the least amount of spring tension.
Old Feb 18, 2008 | 02:50 PM
taifighter's Avatar
Thanks, I was hoping you or some of the other more knowledgeable guys would answer. I seem to hold fine, was just making sure I had it set correctly. Sometimes I get a flutter instead of a clean, full discharge. But that tends to happen more at partial rather than a WOT lift.
Old Feb 18, 2008 | 02:57 PM
cincyTT's Avatar
I'm make believe
part throttle and less boost will have the effect. You cant really tune for both high psi and low psi. THe ssqv is i think the only valve that works that way.
Old Feb 18, 2008 | 03:03 PM
taifighter's Avatar
That's actually a smart design. I knew a couple guys who had SSQs when I ran with a DSM crew. They had the option of putting their meters after the valve, on the upper IC piping, and could vent to atmosphere with no problems. I never liked the sound. It was like it was calling for attention.
Thanks for the info.
S3-WFX
Sep 3, 2012 11:25 AM
Vegas34
May 1, 2008 02:36 PM
Wrona85
Oct 19, 2007 10:30 PM
elvis12
Jun 25, 2006 11:47 PM
courville_s
Apr 13, 2006 12:13 AM
