Looking to swap my cluster
2001 tt i have a new/used cluster. what tool/programer do i need to complete the swap? VAGdashCOM? if so where do you buy one?
now the tach does not work, the oil pressure shows low and the immob light is on. it starts and runs ok.
thanks.
thanks.
No the Ross Tech will not get you what you need. Your easiest (and likely lowest cost) route would be to get it repaired via somewhere like Module Master.
ModuleMaster | Rebuild Info
