Loss of power??
Old Jan 20, 2010 | 06:14 PM
JaceTun's Avatar
Default Loss of power??
Took my car out for a spin today, everything was fine until I decided to have a little fun with the car. I floored the gas and it makes a unusually louder air suction noise, but it gives no power, and when I let go of the gas or shift gears, it does the air exhaustion noise.
According to the Boost gauge, the car was boosting at 18psi peak, so I assume no leak is there??
any suggestions?? Bad MAF? Leaks? Shot turbo???
a 2000 Audi TT FWD
Thank you
Old Jan 20, 2010 | 08:42 PM
JaceTun's Avatar
Problem solved! Some moron re-directed my DV to the wrong position when I took it out to service! I re-hooked it back to normal and now is pulling like a champ again!! glad that I didnt waste anyone's time besides me. Be careful guys when you take your baby out to service, make sure you are going to someone you can trust.
BTW, anyone knows what would happen if I didn't catch the problem and continue running it with the wrong set-up??
Old Jul 6, 2010 | 02:40 PM
Rn3037's Avatar
I have a hyperboost DV and the same issue, I'm going to put it back to stock orientation
Old Jul 17, 2010 | 11:12 PM
hauptjr's Avatar
Earlier today, my boost died. Its been working fine. But now that i'm 250 miles from home, I get a 'whooshing' noise, no power, and a "17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!) P1297 - 35-00 - -
So - the big question is - can I drive the car safely? It seems to handle fine and I can get up to interstate speeds - it just takes longer because I don't have any boost. The big question is - am I going to damage the engine by trying to drive a long distance?
thanks!
Old Jul 18, 2010 | 12:36 PM
jamestown478's Avatar
I had the same issue. It ended up being that my maf sensor was dirty as hell.
Old Aug 6, 2010 | 02:49 AM
fly200's Avatar
Thumbs up
makes me want to go check my sensor now...
steven.whyte
Mar 15, 2012 11:53 AM
01ToplessTT
Oct 22, 2011 12:21 PM
tgsworldwide
Sep 10, 2008 07:37 PM
keyvan
Sep 22, 2007 02:17 PM
whisper
Apr 3, 2007 08:52 PM
