Low boost and chipped ?
Old Jul 23, 2008 | 12:13 PM
mrdavies's Avatar
Default Low boost and chipped ?
I have a 225 tt year 2000, I put a APR (93) chip in it. I then installed a Prosport boost gauge. Im only getting 11psi at the most on my gauge!, and it's effort to get it to that #.
Any ideas ? Would it be a leak? The gauge seems very responsive to my accelerator, so im quite sure all is hooked up right. And yes, I replaced the DV with one from APR.
Thanks
Old Jul 23, 2008 | 12:20 PM
cincyTT's Avatar
I'm make believe
Default RE: Low boost and chipped ?
Well since there is no 225 in 2000, they didnt start till 01. Also 11psi is right on what a 2000 180 would be psi wise. You sure you got chipped and have a 225? Please read the FAQ and make sure
Old Jul 23, 2008 | 12:23 PM
mrdavies's Avatar
sorry, its a 2001
Old Jul 28, 2008 | 10:26 PM
mrdavies's Avatar
hey ... any ideas? This is really bothering me !!!
Old Jul 28, 2008 | 10:46 PM
GHETTOxWHITExBOY's Avatar
you stated it has a 93 chip from apr. do you have it in 93 mode or is it in stock mode ???
Old Jul 28, 2008 | 10:59 PM
XCLR8TT's Avatar
Low power could be due to the MAF being weak. A chip will push a marginal MAF beyond it's limits. Try unplugging it and see if the power comes back. If not, you may have a boost leak.
Old Aug 9, 2008 | 09:42 PM
mrdavies's Avatar
Default problems still, low boost and limp mode
The car goes into limp mode when I drive the car hard. I have to pull over and turn the car off and restart it. I cleaned the MAF, and changed the air filter. The car has a APR flashed 93 chip in it; however Im only getting stock boost numbers! It does not peak above 12, and its very difficult to get it to that. Any ideas people? im not ready to take it to the dealer just yet.
please help
Its a 2001 225
THANKS everyone
Old Aug 9, 2008 | 10:22 PM
theTTkid's Avatar
do you have 1 or 2 programs?
Old Aug 9, 2008 | 10:59 PM
mrdavies's Avatar
I have one program, flashed to 93 octane. I got chipped 6 weeks ago.
Old Aug 9, 2008 | 11:45 PM
Wintermute's Avatar
Water bottle & soapy water is your best friend.
