MAF Nightmare
Old Oct 22, 2009 | 11:22 PM
2alpha56's Avatar
Default MAF Nightmare
Yes, I have searched the forums, with little to no result. 2001 TT Roadster 1.8 FWD basic.
Has thrown the code P1128 for months! Removed MAF, cleaned multiple times. Car starts well, idles well but cuts out and hesitates when attempting to enter freeway, passing, etc. In addition to CEL, Traction Control light now on. According to these forums, another symptom of a bad MAF. Now also throwing code P0102. So I bite the bullet and buy a new MAF and installed it. Traction Control light now off. All codes cleared. Car still cuts out and hesitates. Only 45,000 miles. No other vacuum leaks that I can find. So, on maiden run after being disappointed with the new MAF, unplugged the %*!# thing...OMG...what performance! (Probably need a neck brace now.) Obviously by unplugging it , the problem is the MAF, right? Is there a performance MAF? Have I overlooked something? Any suggestions greatly appreciated.
Old Oct 23, 2009 | 01:13 AM
Mobius97's Avatar
Is it cutting out at high boost? If so could be something as cheap and easy as your plugs.
Old Oct 23, 2009 | 01:38 AM
Midniteoyl's Avatar
Could be a number of things.. unpluging the MAF forces the ECU to revert to a preloaded MAP, ie: its guessing.
Check out the wiring, though people have gotten bad MAF's new.
pinay808
Jun 21, 2013 05:09 AM
tdotA3mike
Oct 29, 2008 12:32 AM
30vQuattro
Feb 25, 2008 03:23 AM
D Bo
Sep 23, 2007 11:50 AM
anna
Dec 28, 2006 12:10 PM
