Max K04 Boost @ 6400 rpm
Old Mar 10, 2009 | 03:23 AM
YAS's Avatar
YAS
Default Max K04 Boost @ 6400 rpm
Hi my first post on this forum
I recently did a K04-023 swap on my car and currently busy with a custom tune. My Mods include
K04-023
440cc
Forge Intake
63mm DP + Exhaust
Water Meth Injection
Would like to no if its safe for the turbo to hold 18psi of boost till redline ie 6400rpm.
What would be the recommended safe boost at that rev?
*Edit to add
What's the max boost i can run at :
5500rpm
6000rpm
6400rpm
Thanks
Old Mar 10, 2009 | 11:10 AM
cincyTT's Avatar
I'm make believe
as long as you dont mess with the wastegate, you arent going to harm the turbo. BTW, your redline should be higher than 6400rpms, stock is 6800 and most chips move it to 7200rpms
Old Mar 10, 2009 | 08:27 PM
myslow1's Avatar
but after the boost is raised from a chip or diode do you really make power that high? I can feel where my power drops off and it is around 6kish..
Old Mar 10, 2009 | 09:43 PM
cincyTT's Avatar
I'm make believe
A ko3 is only making like 160whp at 6500, a ko4 maybe 180whp. Its a big drop off after 6k on both turbos.
Old Mar 11, 2009 | 12:27 AM
myslow1's Avatar
Thats what i figured. I can feel my car lose power around 6k
TeeterTawter
Jan 20, 2013 12:14 PM
audisleepa
Nov 5, 2009 07:36 PM
madman1234509
May 3, 2009 04:23 AM
BUCKET O BOLTS
Jul 28, 2008 08:15 PM
onepoint8tee
Jun 27, 2007 04:38 PM
