mbc location question
Old Apr 7, 2007 | 11:40 PM
fenderstrat1184's Avatar
Default RE: mbc location question
dont crank out more boost than your current tuning can handle
ie if youre stock dont go higher than 5-7lbs
if youre chipped, dont go higher than 19-22lbs
if you run the boost too high without proper fueling, you'll run lean which = very bad
Old Apr 7, 2007 | 11:47 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: fenderstrat1184
stock is 11psi. i have no chip and run 18-20psi!! please stay in the a4 section and refrain from giving poor advice on things you do not know!! THANKS!
but 20-22 is as far as a ko3 can really go, it CAN make more than that but it is just then blowing hot air.
Old Apr 8, 2007 | 12:27 AM
theTTkid's Avatar
Ko3 is the stock turbo for an 02 180 right?
Old Apr 8, 2007 | 12:32 AM
cincyTT's Avatar
I'm make believe
ko3s, but yes
Old Apr 8, 2007 | 12:58 AM
theTTkid's Avatar
hah well im embarrased... thanks
edmhess
Nov 15, 2010 09:33 AM
Stidham
Sep 14, 2010 08:16 PM
Yeff24
Nov 21, 2007 12:23 AM
Darknight101
Sep 30, 2007 12:15 PM
LovemyAudi
Aug 17, 2007 10:21 PM
