more boost
Old Jul 22, 2007 | 01:44 PM
dsrtibb's Avatar
Default RE: more boost
I have a check engine light its a cooling sys malfunction. The sensor is on its way but I dont think that would cause it to go into limp mode would it.
Old Jul 22, 2007 | 01:50 PM
racer_x's Avatar
what cooling system malfunction? the car is definitely in limp mode... what is the mileage? have you checked your plugs/coilpacks?
you would usually throw a misfire code for the coil/spark plug problems.
check all your turbo lines, too. might have a leak. keep us posted....
Old Jul 22, 2007 | 01:51 PM
225tt's Avatar
Hmm dont really think it would, is there only one code being thrown? Do the ECU reset and then see if anything else popps up or if it fixes it. The coolant sensor is only for startup then it should be fine after the car warms up. Remember your 02 sensor could be going out as well. Take it somewhere get the code numbers and then let us know what they are.
Old Jul 22, 2007 | 02:06 PM
dsrtibb's Avatar
theonly code that is showingis 1296
Old Jul 22, 2007 | 05:38 PM
dsrtibb's Avatar
I reset the computer and the boost spikes to14then drops to 12, is this normal for the 180
Old Jul 22, 2007 | 05:46 PM
neur0tic's Avatar
Yes. sounds like your problem is fixed. At least your boost problem anyhow.
Old Jul 22, 2007 | 05:54 PM
dsrtibb's Avatar
Has anyone ever shortened the waste gate rod to get a little more boost?
Old Jul 22, 2007 | 06:09 PM
  #18
cincyTT's Avatar
I'm make believe
That will work, but kill the turbo very fast. Also, move the boost gauge line to the fpr instead.
ps. im nathan/nate
Old Jul 22, 2007 | 06:13 PM
  #19
dsrtibb's Avatar
Thanks for the info
TeeterTawter
Jan 20, 2013 12:14 PM
to4xxx
Jun 8, 2012 11:56 AM
BUCKET O BOLTS
Jul 28, 2008 08:15 PM
eliTTe
Oct 11, 2007 04:12 PM
onepoint8tee
Jun 27, 2007 04:38 PM
