My clutch is shot...Time for new one
Old Dec 13, 2007 | 08:30 PM
jon.alvarez's Avatar
Default My clutch is shot...Time for new one
So now that i knowthe clutch totally needs replacement (thanks for the help/info), what do you guys think is a good deal? i looked into ecs deal for new clutch around $300. Anyone know of any others? Do you guys think i will also need a flywheel?? (clutch severity: no acceleration in 6-3rd gear)
Old Dec 13, 2007 | 08:46 PM
theTTkid's Avatar
Default RE: My clutch is shot...Time for new one
sigh im with ya on the clutch goin.... im going with a spec stage 2+ though... IDK what flywheel yet though
Old Dec 13, 2007 | 09:09 PM
My car is all stock, but i would like to put a basic apr chip in. Should i get a normal clutch?
Old Dec 13, 2007 | 09:32 PM
ouTTie914's Avatar
Do you have any plans of upgrading to a big turbo?
Old Dec 13, 2007 | 10:20 PM
theTTkid's Avatar
going along with outties question... if your just keeping it simple, like a chip and exhaust then you should stay stock... however, once you start getting more powahhh youll need an upgraded clutch... so now would be the right time to ask yourself if you will be going big or not
Old Dec 14, 2007 | 04:12 PM
I just want to put a chip and thats it, what is a good deal for a clutch if i dont want to go big? any links?
Old Dec 14, 2007 | 04:35 PM
bmwtoaudi's Avatar
I have an ECS tuning (Stage 1) FLYWHEEL/CLUTCH - They come together.
I have a APR tuning chip/borla exhast. - Between the 3 mod's I'm more than happy with the cars proformance. - The clutch itself grabs MUCH harder than the stock clutch. - It's great for engine breaking around corners...etc
Make sure you break it in *500 or so miles* before you beat on it. - You dont want to break it!
Old Dec 14, 2007 | 08:17 PM
tom1222's Avatar
A friend of mine has a spec 2+ with a steel lighter weight flywheel and he has a lot of shatter.
He now wishes he would have stayed with the stock dual mass flywheel.
I had my clutch replaced to just a stock oem clutch and pressure plate but they didn't replace my stock flywheel so
I hope that will not give out any time soon. Car runs good but doesn't grab nearly as well as his clutch does.
I would go with the Spec 2+ set up with the stock Dual Mass Flywheel.
Also, why do you have to break your clutch in? It's not like it gets any stronger with use. I am not that hard on clutches
anyway and never need a clutch replaced. I bought this car with a bad clutch but the dealer replaced it with probably
the cheapest thing they could find.
Old Dec 15, 2007 | 02:14 PM
theTTkid's Avatar
... with a 12-14lb steel FW and raising the rpms a little there wouldnt be chatter...
moonstruck
May 6, 2010 03:17 AM
bledsoe24
Mar 7, 2008 10:48 PM
Flyersfan
Aug 16, 2006 03:52 PM
meatbiscuit
Jun 14, 2006 02:33 PM
04a4
May 30, 2006 03:12 PM
