My final mod.
Old Aug 31, 2007 | 05:48 PM
cincyTT's Avatar
I'm make believe
Default RE: My final mod.
ORIGINAL: MeanAudiA6
not sure the headlight washer will be enough but i;m trying to be optimistic
If it can get that much pressure out of the windshield washer AND headlight washer together, it should be more than enough. Plus you just need to MIST the ic, not force the water anywhere.
Old Aug 31, 2007 | 05:57 PM
eliTTe's Avatar
There is actually 2 seperate pumps for windshield and headlights, and the headlight is the stronger one.. I tested the mister nozzle on a windshield sprayer and it was more than enough so I'm sure the stronger headlight pump will easily support 3 mister nozzles.
yeh tcarbon offered to replace it but I don't have the time, so I'll just deal with it.
Old Aug 31, 2007 | 06:00 PM
cincyTT's Avatar
I'm make believe
Just straiten them out and put that on the backside. So are you just disabling the aliens and adding a switch to control the misters?
Old Aug 31, 2007 | 06:05 PM
eliTTe's Avatar
Correct. I just went to advance auto and picked up a nice switch and some wire for $11.84
Old Aug 31, 2007 | 06:07 PM
cincyTT's Avatar
I'm make believe
You really should mount that some place higher in reach so its easier to access.
Old Aug 31, 2007 | 06:10 PM
eliTTe's Avatar
the switch? I just really don't see anyother "clean" place because the dash and everything on the TT is so symetrical.
Old Aug 31, 2007 | 06:13 PM
cincyTT's Avatar
I'm make believe
What about near the shifter? There is a couple places that should suffice there. you have a push to activate switch or a toggle style?
Old Aug 31, 2007 | 06:16 PM
  #18
eliTTe's Avatar
its a toggle switch, on or off you don't have to hold it... I would put it in the ashtray area but my GPS is there.
Old Aug 31, 2007 | 06:35 PM
  #19
MeanAudiA6's Avatar
dont you think the push type switch would work better? but if you do use a toggle check this out from radioshack.com its pretty cool reminds me of Top Gun i dont know where i would put it other than in the sliding compartment under the ashtray
http://www.radioshack.com/product/in...entPage=family
Old Aug 31, 2007 | 06:39 PM
  #20
cincyTT's Avatar
I'm make believe
I think the push type would be nice to just spray it for a sec or two and then its off.
