My Headlights are sweating!!!!
Old Nov 6, 2006 | 11:09 AM
TeeTee's Avatar
Default My Headlights are sweating!!!!
Hello please help my headlights are sweating all the time! What can I do about this problem??? Maybe there are some other ways to solve this situation like smashing both headlights and go to my insurer???? Thanks
Old Nov 6, 2006 | 03:47 PM
Palindari™'s Avatar
Default RE: My Headlights are sweating!!!!
Sounds like you have an obvious seal leak somewhere - new headlamps will cure that - I wouldn't try to chase it down unless it's completely obvious and not on the outside cover...
Old Nov 6, 2006 | 03:49 PM
racer_x's Avatar
The headlights are fairly easy to take apart, but it's time consuming. Look for the RISO clear corners install for complete instructions on taking them apart. You may need new epoxy.
Old Nov 7, 2006 | 11:38 PM
achTTung's Avatar
get the riso clear corners while you're at it!
Old Nov 8, 2006 | 01:03 AM
XCLR8TT's Avatar
And paint the inner housing to match the body color.
Old Nov 8, 2006 | 12:44 PM
MeanAudiA6's Avatar
lol...i want to take mine out to get some damn little dead spiders out of there and to put the clear corners in.
Old Nov 8, 2006 | 03:54 PM
Palindari™'s Avatar
Noticed some headlamps have the reflector that runs up the side and others do not... is this a year model difference or something?
Old Nov 8, 2006 | 05:03 PM
achTTung's Avatar
either you take them out, or you buy euro spec assemblies. All assemblies made for the US have the reflector.
Old Nov 8, 2006 | 06:18 PM
Palindari™'s Avatar
Is this an easy disassembly? Or what I'm asking is, removing those reflectors - will there be a blank spot? Would it be just easier to order the Euro spec style?
Old Nov 9, 2006 | 01:16 AM
2doors1hatch's Avatar
DIY is always cheaper
check out this link:
http://www.loomknitting.com/auditt/
go to mechanical mods and scroll....
you'll find the reflecter mod
the headlights are easy to take apart but NOT the easiest to put back together
i had issues SEALING them up but so far so good!!!!
