MY TT OUT OF CONTROL!
Old Mar 24, 2006 | 01:23 PM
sbvg's Avatar
Default MY TT OUT OF CONTROL!
GREETINGS FELLOW TT LOYALIST! I HAVE AN 01 180 HP FW TT ROADSTER IT'S @ 71000. TT RUNS GREAT HOWEVER,
JUST IN THE PAST 3 WEEKS FIRST THE TURN SINGNAL BLINKS 2 TO 3 TIMES AND JUST GOES OUT OR SOME TIMES NO
LIGHT AT ALL, YOU CAN MANUAL TRY TO BLINK THE LIGHT TO TURN BUT IT WILL STILL GO OUT AFTER 2 TO 3 BLINKS. IT
ALMOST SEAMS TO FADE OUT WHEN YOU WATCH THE LIGHT. NOW FOR THE ROASTER OWNERS THE DRIVER SIDE
WINDOW WILL NOT GO
UP THAT HALF INCH WHEN YOU CLOSE THE DOOR ? WHICH MAKES THE CAR MAKE THE ANNOYING BEEPING SOUND
WHEN YOU ARE DRIVING, ALSO WHEN YOU OPEN THE DOOR SOMETIMES IT WILL DO THE OPPOSITE THE WINDOW WILL
GO UP AND WHEN YOU CLOSE THE DOOR IT WILL GO DOWN ANYWAY I CAN NOT SET THE ALARM IF THE WINDOW IS
DOWN???? WHAT'S UP AND JUST TONIGHT I TURN THE LIGHTS ON AND A LONG BEEP AND A NEW SYMBOL CAME ON (
LIGHT BULB WITH AN X THRU IT) AND THE INTERIOR LIGHTS THAT LIGHT THE SPEED GAGE..ECT DO NOT GO ON AND
THE CHECK ENGINE IS NOW ON?? THE CAR IS OUT OF CONTROL! I'M GOING TO THE SHOP BUT I WOULD LIKE TO
KNOW WHAT YOU TT LOYALIST THINK? ON WHAT'S GOING ON, PRICE TO FIX SO ON. SO I DONT GET TAKEN FOR A
RIDE MYSELF! THANK YOU VERY MUCH FOR ANY FEED BACK
Old Mar 24, 2006 | 02:19 PM
Jestnomen's Avatar
6th Gear
Default RE: MY TT OUT OF CONTROL!
Welcome to the forums. Please don't use caps, it makes it very hard to read your post.
Old Apr 2, 2006 | 11:26 AM
dankhound's Avatar
Sounds like you have quite a few problems going on. The turn signal issues are caused by a faulty hazard switch. The window and alarm issues are caused by a bad open/closed switch in the door latch. The bulb with an x thru it means you have a light out. And the cel can be just about anything.
Old Apr 5, 2006 | 02:24 AM
quattro411's Avatar
might have a blown fuse or two, check your fuse box
akasjl
B8 Models
May 2, 2014 06:03 AM
JDriver2
Jul 10, 2006 11:16 PM
