N249 Delete DIY
Old Jan 3, 2018 | 12:53 PM
Hamood Prince's Avatar
Default i have the ones with the yellow top
Old Feb 26, 2018 | 09:09 AM
hichamaziz's Avatar
thank you for post
Old Oct 12, 2021 | 08:53 PM
ArTTst's Avatar
Question on this, hopefully someone can see since it's been a few years...
I'm still getting the incorrect flow code (0411). A few differences from this:
1. The N112 valve is capped. I'm running a straight line from the DV to the IM.
Should I have a T running between the three (DV, IM, N112)?
2. I used a 5W 330-ohm resistor, instead of a 10W. I didn't think there would be that much load for a sensor.
Hopefully someone who has run into the same issues can help.
Old Nov 1, 2021 | 08:03 PM
ArTTst's Avatar
Thumbs up
It looks like the problem was indeed the N112 not having vacuum. In other guides and videos, they all seem to mention just capping the N112 and the P0411 code is never mentioned.
I have no codes now after supplying vacuum to the N112. Wish the other guides I've found covered this issue. Thanks for this info.
whitejeepXJ
Oct 29, 2009 12:21 AM
AWDrifter
Feb 11, 2009 08:23 PM
l88m22vette
Oct 2, 2008 05:06 PM
MeanAudiA6
Apr 7, 2008 06:03 PM
pimphell
Mar 26, 2008 12:09 AM
