Need some help
Old Apr 22, 2008 | 07:33 PM
theTTkid's Avatar
Default RE: Need some help
I get the idea, but if you felt like posting pictures or just emailing them (greg808@gmail.com), that would be great. How do I get past the back seats, still under the trim or just tucked next to them?
Thanks,
Greg
can be easily tucked between the seats... ill go look at my sub cables and see whats up. forgot how they are run
Old Apr 22, 2008 | 07:40 PM
theTTkid's Avatar
alright, im pretty sure pulling up the rear seat is easy, so is running the cable along the drivers side under those plastic panels... its hard to get pictures because you cant see my wires and i dont really feel like pulling up the plastic.
though if the weekend comes and you still need some help let me know... is this just temporary or are you keeping the cable in?
Old Apr 22, 2008 | 08:02 PM
greg808's Avatar
Not temporary. It will be about as permenant as a sub install. I will keep it as long as I have the car. I am pretty sure I know have the information to get from the battery to the rear seats. I will take a look at how that will go. Once I am past those, I am home. The cable can run by the spare tire and up into the little compartment by the driver's side taillight where the modulite is located.
Thanks again.
Greg
Old Apr 22, 2008 | 08:17 PM
theTTkid's Avatar
no problem, let us know
Old Apr 29, 2008 | 05:17 PM
greg808's Avatar
Ok, I had the day off and put some time into doing this. It went well, thanks for all the help. One note, I did not use the AWE-tuning instructions to get the wire into the passenger compartment, they seemed a little complicated. I just used the grommet that can be seen and went through that. I used this link (http://www.audiworld.com/tech/elec.html). Working the wire into the trim took some time, but it install was a sucess.
Thanks again,
Greg
Old Apr 29, 2008 | 05:34 PM
achTTung's Avatar
got pics of how the hitch mounts? I'm curious, not a lot under there I'd consider solid enough to use as an anchor.
Old Apr 29, 2008 | 05:48 PM
greg808's Avatar
I can take a picture if you like, but the install instructions are at this link. Take a look and if you would like a picture of the actual thing, let me know.
http://www.etrailer.com/instructions.aspx?pn=11765
Greg
