Net torque seems low...
Old May 27, 2008 | 06:00 PM
Dfminc's Avatar
Default Net torque seems low...
So I just took my 225 TT with mbc set to 15 psi and logged my net torque. The highest value I got throughout the third gear pull was 164.8 N/m. When I convert that to lbs/ft I get 121.6. Seeing as the stock 225 came with 207 lbs/ft(maybe??) I'm somewhat confused. Is the low torque reading accounted for by quattro driveline loses or is something amis?
Old May 27, 2008 | 06:03 PM
randomloginname's Avatar
Default RE: Net torque seems low...
is that the diff between crank and wheel? if its supposed to be 207 crank w~20-25% quattro drivetrain loss, then the # sounds about right.
Old May 27, 2008 | 06:22 PM
Dfminc's Avatar
A twenty-five percent loss would leave you with about 155 lbs/ft of torque. My loss would be about fourty-five percent. Abnormal?
Old May 27, 2008 | 06:57 PM
Dfminc's Avatar
I've noticed that starting around 2600 rpm I get 3 degrees of timing pull(if that is what block 20 is telling me) which increases up to 11 degrees of timing pull at 600 rpm. From what I understand I shouldn't be seeing numbers like that! What could cause this?
Old May 27, 2008 | 10:13 PM
myslow1's Avatar
ORIGINAL: Dfminc
what are your mods?
Old May 28, 2008 | 12:45 AM
Dfminc's Avatar
I had a diode in but the boost was still only set at 15 psi. So I put everything back to stock and am now getting 8 degrees of pull in the upper rev range. That still seems fairly aggressive for stock.
Old May 29, 2008 | 01:27 PM
cincyTT's Avatar
I'm make believe
Could be the heat or gas. But you are low and that probably is the cause
occhis
Apr 30, 2009 09:43 PM
bigern45
Nov 25, 2008 12:44 AM
krystallbluea4
Nov 13, 2008 01:50 PM
edkwok
Nov 16, 2006 06:45 PM
cireecnop1
Oct 29, 2005 05:30 PM
