Net torque seems low...
So I just took my 225 TT with mbc set to 15 psi and logged my net torque. The highest value I got throughout the third gear pull was 164.8 N/m. When I convert that to lbs/ft I get 121.6. Seeing as the stock 225 came with 207 lbs/ft(maybe??) I'm somewhat confused. Is the low torque reading accounted for by quattro driveline loses or is something amis?
I've noticed that starting around 2600 rpm I get 3 degrees of timing pull(if that is what block 20 is telling me) which increases up to 11 degrees of timing pull at 600 rpm. From what I understand I shouldn't be seeing numbers like that! What could cause this?
ORIGINAL: Dfminc
I had a diode in but the boost was still only set at 15 psi. So I put everything back to stock and am now getting 8 degrees of pull in the upper rev range. That still seems fairly aggressive for stock.
