O2 Sensor Circ.,Bank1-Sensor2 Malfunction
Old Mar 1, 2008 | 11:09 PM
vertic's Avatar
Default O2 Sensor Circ.,Bank1-Sensor2 Malfunction
my car had check engine light and i got it read it came out with code number p1136
when i checked what the code means it read as folows O2 Sensor Circ.,Bank1-Sensor2 Malfunction
i dont know if it is the actual o2 sensor or mass flow sensor bad.
if someone know can you please let me know
thanks
Old Mar 1, 2008 | 11:45 PM
themysteryman83's Avatar
Default RE: O2 Sensor Circ.,Bank1-Sensor2 Malfunction
Check wiring to the sensor. Check for vacuum leaks. Unmetered air leaks will often throw this code. Check and make sure your gas cap has a good seal on it. If you know someone with a vagcom then get them to read it or invest in one yourself.
Old Mar 2, 2008 | 01:38 AM
ouTTie914's Avatar
It's a lean code... Have you recently installed a boost gauge?
green2man0
Oct 5, 2014 02:28 PM
carlton11
Jul 8, 2014 11:00 PM
shavrovas
B7 Models
Dec 30, 2011 06:32 PM
oneg
Dec 12, 2007 03:10 PM
