Occasional loss of power?
Old Oct 22, 2006 | 11:49 AM
Chiefs_TT's Avatar
Default Occasional loss of power?
I recently experienced a problem where with full throttle I was unable to get any more that 1000rpm (roughly idle). Without doing anything the problem went away. Now, occasionally I experience a flat spot in the power around 3500rpm where the turbo would usually start to do its stuff. I keep my foot planted then after a couple of seconds I seem to get all of the power in one huge burst. At first I thought I had a loose connection in the drive-by-wire throttle mechanism but now I'm worried that it might be a problem with the turbo itself. Any thoughts?
Old Oct 22, 2006 | 01:39 PM
AudiEddie's Avatar
Default RE: Occasional loss of power?
How many miles do you have? I think your supposed to change the turbo's around 100k.
Old Oct 22, 2006 | 01:48 PM
XCLR8TT's Avatar
ORIGINAL: AudiEddie
The turbo will last well over 100K.
Sounds like your problem could be plugs, coilpacks, or possibly a bad MAF. The best thing to do is get a hold of a copy of VAG-COM. First thing to do is check to see if there are any fault codes that have been recorded. After that do a WOT in 3rd gear from 2000 RPM to Redline while logging channels:
002: Mass air G/sec
118: Intake temp/N75 Duty Cycle/IC pressure
204: Command, IC, and Manifold pressures
032: Partial throttle , Mass air G/sec
Old Oct 22, 2006 | 04:38 PM
Palindari™'s Avatar
Damn! That's all Greek to me, mate!
Had something like what you descibed happen. When driving in 4th/5th gear the turbo warning light would flash with absolutely no response to throttle. If I lift off the gas I would slowly lose speed - if I didn't I would simply continue on at what ever speed I was at. Then one time I was frustrated and disengaged the ESP and I regained control. Drove about 2 or 3 miles like that and reengaged the ESP and all has worked well since - crossing my fingers.
Does anyone know what that was all about?
Old Oct 22, 2006 | 07:18 PM
racer_x's Avatar
Cracked / blown line in the turbo system? Get a boost guage!!
Old Oct 22, 2006 | 09:32 PM
Palindari™'s Avatar
Idiot question #14 and counting... lol
What will a boost guage tell me exactly, mate? And I'll have the turbo checked here tomorrow, thanks!
Old Oct 23, 2006 | 01:45 AM
racer_x's Avatar
No such thing as an idiot question! ....just annoying ones :P
Juuuust kidding, just kidding. We've all got to start somewhere, right? Well, a boost guage is basically going to tell you the PSI (pounds/sq. in.) of your turbo system. Search this and the audiworld forums for specific information about where your turbo should be boosting. You can also (crudely) log your boost @ RPMs (in a specific gear, 3rd is usually used for this). Ideally, you want to have the car scanned by someone with 'VAG-COM' software. You can buy your own, but you'll need someone to explain your results. You could also post them in here!
Anyway, about the boost guage -- with a little research, you will be able to determine if your turbo system is boosting properly.
I bought a boost/vac guage, awaiting delivery now (just getting the car tomorrow). It's a great way to diagnose your turbo system's health!
steven.whyte
Mar 15, 2012 11:53 AM
kwaskow
Jul 31, 2010 05:24 PM
tgsworldwide
Sep 10, 2008 07:37 PM
pliberatos
Oct 14, 2007 01:55 PM
coupester
Mar 27, 2006 11:41 PM
