oil catch can
is this what people are using for the homemade oil catch cans? CincyTT? lol you have to put this in the search field 100027474
http://www.homedepot.com/prel80/HDUS...0&MID=9876 |
RE: oil catch can
that is the exact one on my car. all you need is a few $ in fittings and hose.
RE: oil catch can
hmmm site has nothing to do with oil change more for a sales advert if you ask me
RE: oil catch can
sweet! i'm trying to find the fittings on that site but no luck guess when i go in there to buy it i'll just open the package and go around pluging stuff in to it till it fits. lol did you use just some heater hose from like NAPA? i might actually have some left over silicon that might work.
So all you have to do is cut that formed hose coming from the block and the hose steming from the turbo boost pressure regulator(black flat circle top piece) and put the catch can in between them? |
RE: oil catch can
I use an old oil can and cut the side off ( plastic of course ) 5 litre in and 5 ltrs out or what ever quarts you use ( all it is is a catch bin )
RE: oil catch can
ORIGINAL: MeanAudiA6 sweet! i'm trying to find the fittings on that site but no luck guess when i go in there to buy it i'll just open the package and go around pluging stuff in to it till it fits. lol did you use just some heater hose from like NAPA? i might actually have some left over silicon that might work. heater hose will work fine. |
RE: oil catch can
homemade oil catch cans? now its converted to coolant change what are you doing??
RE: oil catch can
ORIGINAL: avant80@2.6 homemade oil catch cans? now its converted to coolant change what are you doing?? here https://www.audiforums.com/m_443365/tm.htm |
RE: oil catch can
Avant, Its to filter oil out of the crankcase breather from entering the intake and turbo. Nothing to do with oil changes or coolant.
RE: oil catch can
oh hell what a dip im not used to this but I understand what your talking about so ill read up on it ( watch out though im quick on the uptake ) im sure he mentioned an oil change though.
is this what people are using for the homemade oil catch cans? CincyTT? lol you have to put this in the search field 100027474 |
