The filter pictured and linked are the same thing and the bowl have been intact on my car for almost 2 years now, so i wouldnt worry about it.
The regulator controls the flow (thus regulator) and once you have a can to slow down the flow, the reg is no longer needed so you can toss it or keep it. |
The regulator? Is that the flat round plastic thingy that ouTTie914 is still hooked up to?
I guess that is why ouTTie isn't using the 90degree brass elbow since it is still running into the regulator. |
That is the reg. My fitting is way smaller than that btw. you can also get a black plastic one from the parts store for a coolant line.
I am still a bit confused. So this fitting either HUGE brass or Black Plastic gets installed in place of that big Round Plastic Regulator. I am glad it can be smaller since that Brass one is pretty huge and pretty ugly ;) Going to the Hardware store tonight and see if I can get all the parts.
Thanks CincyTT for your help! |
My fitting is small and you cant really see any of it unless you look for it. So there are plenty of options out there you can do.
