oil catch can
oil catch can
is this what people are using for the homemade oil catch cans? CincyTT? lol you have to put this in the search field 100027474
http://www.homedepot.com/prel80/HDUS...0&MID=9876
RE: oil catch can
sweet! i'm trying to find the fittings on that site but no luck guess when i go in there to buy it i'll just open the package and go around pluging stuff in to it till it fits. lol did you use just some heater hose from like NAPA? i might actually have some left over silicon that might work.
So all you have to do is cut that formed hose coming from the block and the hose steming from the turbo boost pressure regulator(black flat circle top piece) and put the catch can in between them?
RE: oil catch can
ORIGINAL: MeanAudiA6
heater hose will work fine.
RE: oil catch can
ORIGINAL: avant80@2.6
homemade oil catch cans? now its converted to coolant change what are you doing??
here https://www.audiforums.com/m_443365/tm.htm
RE: oil catch can
oh hell what a dip im not used to this but I understand what your talking about so ill read up on it ( watch out though im quick on the uptake ) im sure he mentioned an oil change though.
