Oil change?
Old Jan 21, 2007 | 11:05 PM
MasswholeTT's Avatar
Default Oil change?
Hey guys....are there any special tools needed to do a oil change for a 2002 audi tt 180? I just dont want to get under there and not have the special audi only wrench for the oil pan or filter lol....or turning the wrong way for a hour (lefty tighty? lol) also and recomentions as far a lifting the car up? I have ramps but the front end is to low to drive up them......Thanks inadvance!!!!
[IMG]local://upfiles/29613/7AA4745E9B0A4B7C9610440BED8ECB6A.jpg[/IMG]
Old Jan 21, 2007 | 11:49 PM
cincyTT's Avatar
I'm make believe
Default RE: Oil change?
use jack and stands. The plug is a 17mm bolt. the filter is kind of a pita to get to and get lose the first time (stupid shops trying not to get sued). But you might wanna use a plastic bag or something to catch the oil out of the filter otherwise you will have some cleaning to do. Also if you run a new larger passat oil filter you can run another .5 quarts or so.
Old Jan 22, 2007 | 10:56 AM
225tt's Avatar
What year Passat?
Old Jan 22, 2007 | 01:28 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: 225tt
What year Passat?
they redesigned the b5's due to oil sludge sice it only held about 3.5qrts. So look for a 98-01 filter.
napa filter, passat filter, reg 1.8t filter.
Old Jan 22, 2007 | 06:47 PM
225tt's Avatar
Thanks for the info, may work will with my oil cooler that is going to get put on this spring.
Old Jan 22, 2007 | 09:03 PM
MeanAudiA6's Avatar
yeah i cant wait to do the oil cooler mod i figure about 4 hrs to do the whole thing... who knows, every time i install something i account an hr or so for that "unexpected thing" to happen, creating more time for the original mod
Old Jan 25, 2007 | 04:10 AM
proxeyed's Avatar
How many quarts of mobil 1 should I buy tommorow? What about the weight? I plan on using the napa 1333, only because it's the easiest for me to get, but is there another filter I should try? Thanks!
Old Jan 25, 2007 | 04:15 AM
cincyTT's Avatar
I'm make believe
ORIGINAL: proxeyed
if you plan on using that monsterous filter you need 6quarts. I think the passat filter uses close to 5,5quarts and the regular filter uses close to 5qrts. You can always use something else available at the parts store like mobil one or bosch, of even a fram if you want to.
the recommended weight is 5w 40 or 0w40 full syn. I have only seen castrol in 5w40 and mobil one in 0w40 where i live.
***change qrts for size, recheck the old thread
Old Jan 25, 2007 | 04:26 AM
proxeyed's Avatar
thank you sir
Old Jan 25, 2007 | 04:59 AM
Cameron's Avatar
With the larger filter we fill 4.5 quarts in the 1.8T at work. If you aren't sure if you are getting the right size filter, just compare it to a Ford 5.0 filter - it will be the same size, and possibly bigger (not sure exactly how big that Napa monster is).
Little fun fact - you can use the your Audi filter on a 5.0, but not the other way around.
