oil filter threads info
Old Mar 21, 2007 | 02:57 PM
Dana Reed's Avatar
Default oil filter threads info
This is a longshot, but does anybody know the thread size & pitch for the oil filter adapter? I'm looking in to riggin up a remote oil filter & you can buy the components individually.
Old Mar 21, 2007 | 08:49 PM
ttoo cool's Avatar
Default RE: oil filter threads info
I can tell you how to find out:
1. Go to any NAPA
2. Find the oil filter for your car
3. Take the oil filter over to the bolts and nuts section.
4. Find which size bolt your oil filter will screw onto.
5. Record the size. Each bolt should have it listed.
To find the size or the actual oil filter measure the diameter at the widest point. If it is hard to determine the exact middle simply measure the circumference and solve algebraically wi the following formula:
Circumference/Pi = Diameter.
Hope this helps and good luck!
A4 Jed
Jun 23, 2013 06:13 PM
aledelic42
Sep 9, 2011 01:41 AM
swyne
Jun 15, 2010 04:57 PM
Agnt008
Feb 29, 2008 02:11 PM
EVOLA4
Feb 5, 2008 06:34 PM
