Oil in Forge Spliter?
Old Apr 8, 2008 | 02:01 PM
CJRando's Avatar
Default Oil in Forge Spliter?
I just chnanged my oil on my 2001 TT 225 quattro. I noticed there was some oil on my Forge splitter valve, not a large quanity. Is this fairly normal? Is it something tha I can correct with a catch can?
Old Apr 8, 2008 | 03:08 PM
ouTTie914's Avatar
Default RE: Oil in Forge Spliter?
On the valve... as in the outside of it?
Old Apr 8, 2008 | 03:30 PM
myslow1's Avatar
you will have some oil in the pipes from blowing through, when the dv cracks there is a chance some oil might come out. A catch can will solve that...
Old Apr 8, 2008 | 03:51 PM
ouTTie914's Avatar
Holy hell how much boost are you pushing for the DV to crack?!?
Yes the there is suppose to be some oil in the intake, but on the valve... that's a first to me!
I'm willing to bet there is oil in your intercooler, as well as covering your IAT sensor.
Old Apr 8, 2008 | 04:34 PM
myslow1's Avatar
ORIGINAL: ouTTie914
i will almost gurantee there is... In order to have oil spew out of the dv or bov there is a good amount of out in the charge pipes and or intercooler. My brother had some coming out of his HKS on his mr2, he pulled his intercooler out and there was a good amount of oil in it. He got a catch can and never had the problem again.
Old Apr 8, 2008 | 04:41 PM
Audi Addict's Avatar
I have a lght coat of oil on mine, but the Y pipe off of the breather is also a bit cracked so....
~I have seen many with a bit of oil that are running stock vaccum hose set-up. If you reroute and clean up the hoses and move the DV to the cold side piping, the problem is not as bad.
Old Apr 8, 2008 | 05:03 PM
ouTTie914's Avatar
ORIGINAL: myslow1
ORIGINAL: ouTTie914
The catch can works fairly well. Mine has caught just about a teaspoon since installed sometime in November '07.
Still some oil gets through, however not nearly as much.
Old Apr 8, 2008 | 05:07 PM
theTTkid's Avatar
yea i had a little oil come up and build up on my BOV... mother effer blew off when i was driving down the highway.. had to pull over and basically put a band aid on it until i could get real parts
dantdi-bj11
Aug 26, 2012 02:26 AM
alex05
May 17, 2008 12:13 AM
jcyj2
Sep 10, 2007 01:09 PM
vegastt
Sep 4, 2007 12:18 AM
TurboToughTT
Jun 19, 2007 03:19 PM
