Oil pan leaking..helpp!!
Old Aug 25, 2008 | 10:01 PM
MeanAudiA6's Avatar
didnt i jsut say i have that plug? i havnt had any issue with that ecs plug and know many that use it....maybe they shipped you the wrong size mine fits perfect and never had a leak
Old Aug 26, 2008 | 08:55 AM
nycsweetestt's Avatar
thanx for your help guys im guess im gonna try the dealent first.. hopefull that works!!! if not i'll just replace the whole thing... thanx again!!!
Old Aug 26, 2008 | 03:44 PM
jakej's Avatar
Originally Posted by ttex
The problem is most likely that you bought the ECS magnetic drain plug. I purchased one a couple of oil changes ago and I quickly realized that it was to big for the hole (a common issue I encounter!). I quickly chose not to install it and to dig my old plug out of the recycling bin, if I had used it I would have most certainly stripped the threading.
I called ECS Tuning and they informed that they had recieved several similar complaints about the same plug on 1.8t on the 225 model only and gave me a full refund. Lesson, do not risk buying this plug if you have a 225.
Those effing bastered sold me the wrong size too! I put it in loose and it distroyed my oil pan. AVOID THE ECS PLUG!!!!!!
Old Aug 26, 2008 | 03:50 PM
cincyTT's Avatar
I'm make believe
LOL, it isnt just the 225.... you know, since they all use the same plug
Old Aug 26, 2008 | 09:05 PM
MeanAudiA6's Avatar
im surprised you guys are having problems with them ya i thought all 1.8t has the same oil pan and plug...are you guys cross threading them?>
Old Aug 27, 2008 | 06:21 PM
jakej's Avatar
No, I'm pretty sure I didn't. I finally called ecs today and got my $12 back. They said it had occured before, so I don't think it's a cross tread issue. More likely a made in china issue.
I wounder if your ecs plug "just barely works" and over a year or so it strips?? I think the thread pitch is just slightly off.
Old Aug 27, 2008 | 06:49 PM
cincyTT's Avatar
I'm make believe
I think the pitch would have to be off since so many people have ruined the threads with them. Plus i still cant believe people are paying $12 for them when they can get one from AZ for $4
Old Aug 27, 2008 | 07:52 PM
  #18
jakej's Avatar
It is a much nicer plug then AZ, the magnet is about 10 times larger... it just doesent fit.
Old Aug 27, 2008 | 07:57 PM
  #19
cincyTT's Avatar
I'm make believe
Mine is atleast the same length. It was plenty long to pull the oil squirter and hold it until i could drain the oil
Old Aug 28, 2008 | 08:06 AM
  #20
sooo which one should i buy and from where??
