Oil pan leaking..helpp!!
Old Aug 28, 2008 | 08:28 AM
  #21
beachchair's Avatar
Originally Posted by nycsweetestt
sooo which one should i buy and from where??
I have a hard time doing this, but I would suggest just going to the dealer and buying several at a time. Because of the washer, the OEM plugs should be replaced with each oil change.
Old Aug 28, 2008 | 01:18 PM
  #22
chosos's Avatar
fumoto valve.
Old Aug 28, 2008 | 06:49 PM
  #23
jakej's Avatar
The valve might leak too. I had a fram e-z drain deal once and it was cool at first, expect overtime when it got dirty it was hard to use.
Old Dec 31, 2008 | 07:23 PM
  #24
chadsummers's Avatar
Hey, I have a leaky oil plug also and I'm sure it is probably the aluminum pan and not the plug. However, I can snug it up pretty good and put a little rubber sealant around it to stop the leak. Any reason I could not replace the plug with the quick oil drain plug mentioned above and seal with rubber sealant... Better yet, I guess I could just make it permanent with JB WELD???
Old Dec 31, 2008 | 08:32 PM
  #25
XCLR8TT's Avatar
Any reason you resurrected a 4 month old thread?
Old Jan 1, 2009 | 10:45 PM
  #26
achTTung's Avatar
he's sorta got a question....
i'd seal up a quick drain plug as a fix, but not so permanent that you couldn't remove it again if you needed to.
drobrt
Sep 30, 2008 03:31 PM
davea407
Jul 29, 2008 01:20 AM
physqoparty
Aug 9, 2007 12:56 PM
Bryceaudi
Jul 31, 2007 03:42 AM
1.8TurboAudi
Mar 5, 2007 02:10 AM
