oil weight
Old Jan 12, 2008 | 02:31 AM
necra88's Avatar
Default oil weight
i got an 01 audi tt, with 76k miles on it. Ive been putting 5w-30 in it for some time now, but i was un sure if they used 5w40 or not in the past. Is there a big difference in the two oil's and is it to late to switch to 5w-40?
Old Jan 12, 2008 | 07:07 AM
beachchair's Avatar
Default RE: oil weight
SAE 5W40 is "Preferred" 5W30 is acceptable also. Use only synthetic oils.
Old Jan 12, 2008 | 12:34 PM
cincyTT's Avatar
I'm make believe
you need a 502 approved oil. The only 5w30 i know off the top of my head is valvoline synpower.
Old Jan 12, 2008 | 05:41 PM
joshuo's Avatar
syntec 5w40 is good right?
isn't the 502 standard the lowest vw standard there is?
kinda surprises me the TT falls under that. [&:]
Old Jan 12, 2008 | 05:56 PM
cincyTT's Avatar
I'm make believe
yes, syntec is fine. The 502 is the old standerd when the TT was new. There is now a 505 standard. I posted a pdf a couple of times that has all of both listed.
Old Jan 12, 2008 | 08:41 PM
joshuo's Avatar
hmm, interesting.
So any oil that meets the 502 or the 505 is good?
Old Jan 12, 2008 | 08:46 PM
cincyTT's Avatar
I'm make believe
they all should be fine for 5k miles or more and prevent sludge from forming and harm to the engine/turbo.
Old Jan 13, 2008 | 01:45 AM
laboomba's Avatar
cincy, I am a bit lost now... I could have sworn you said 0-40w was the preferred weight. mobil 1 0-40w is what I used last, about 2000 miles ago, is this ok?
Old Jan 13, 2008 | 07:43 AM
beachchair's Avatar
From Bentley Manual
5W40 (preferred) - All Engines: 2000-2006
5W30 - 1.8L and 3.2L
0W40 - 1.8L and 3.2L: 2005-2006
Old Jan 13, 2008 | 11:16 AM
cincyTT's Avatar
I'm make believe
ORIGINAL: laboomba
It is an approved oil, i used it myself also. I said the only 5w30 502 approved i knew was the the synpower.
Here is all 502 and 505 approved oils.
Its going in the FAQ for future referance
