is one mbc as good as another?
Old Jul 10, 2007 | 06:46 AM
chosos's Avatar
Default is one mbc as good as another?
or are certain ones better than others? I need a cheap option to replace my n75, as it may be on its way out (i have no way of swapping it to test it).
Old Jul 10, 2007 | 12:23 PM
cincyTT's Avatar
I'm make believe
Default RE: is one mbc as good as another?
for a stock turbo, a bleed valve is better because it will be far smoother than a ball and spring mbc.
incabin mbcsmooth and only $22
combo mbc (ball and spring/bleed valve) spool faster and still make it smooth with no high spikes $44
I have a real combo mbc from turboxs and i enjoy it very much. my brother uses the incabin one and is extremely smooth. Pics of both installed are in my sig.
Old Jul 10, 2007 | 01:23 PM
gravitt's Avatar
I found the Modshack Boost Machine to be easily tunable-- with two different valves to modulate (one controlling the onset of boost and one controlling its release). A little pricey but it certainly modulates spikes, and thus prevent me from going into limp mode, as well as let me hold boost 2-3 psi higher and for a longer time.
www.modshack.info
Old Jul 10, 2007 | 01:30 PM
cincyTT's Avatar
I'm make believe
so its just like a normal mbc....neat.
Its just a really bulky, overpriced ball and spring/bleed valve that can be had for $50-100 that will take up 1/8 the space.
wow, look how massive thats not, AND it fits under the engine cover.
16v vw
Feb 15, 2011 04:05 PM
davidliu1688
Jan 21, 2008 03:55 AM
sdsteez
Apr 19, 2007 03:03 AM
