One touch window problem
So ever since I disconnected my battery a few weeks ago, my one touch window feature no longer works on either of the windows... I think it originally worked on driver side after disconnection of batter but now it doesn't work on either side. Anyone have any ideas of how to reset it or should i call the Audi Dealer to see if they know?? Is there a fuse for these?
follow this process.... up up down down left right left right b a b select start.... wait, wrong code.
Thats right, its this one....
put the windows all the way down, the click the windows down again. Put the windows all the way up and click up. That should work. If it didnt, do it again until it does.
I always had trouble getting the one touch to set on the TT. What i do remember is you have to have the door shut, (or latch closed) and alternate from holding the button up, then down, and up, then down again until it learns the position.Other audi'sare easy as s*** to set.
ORIGINAL: cincyTT
ORIGINAL: auditech79
The TT is the only car you have to have the door shut to program the one touch feature, the A4 and A6 can have the door open with no problems.
