One touch window problem
Old Feb 21, 2008 | 12:38 AM
Agnt008's Avatar
Default One touch window problem
So ever since I disconnected my battery a few weeks ago, my one touch window feature no longer works on either of the windows... I think it originally worked on driver side after disconnection of batter but now it doesn't work on either side. Anyone have any ideas of how to reset it or should i call the Audi Dealer to see if they know?? Is there a fuse for these?
Old Feb 21, 2008 | 01:20 AM
cincyTT's Avatar
I'm make believe
Default RE: One touch window problem
follow this process.... up up down down left right left right b a b select start.... wait, wrong code.
Thats right, its this one....
put the windows all the way down, the click the windows down again. Put the windows all the way up and click up. That should work. If it didnt, do it again until it does.
Old Feb 21, 2008 | 01:56 AM
auditech79's Avatar
I always had trouble getting the one touch to set on the TT. What i do remember is you have to have the door shut, (or latch closed) and alternate from holding the button up, then down, and up, then down again until it learns the position.Other audi'sare easy as s*** to set.
Old Feb 21, 2008 | 02:01 AM
cincyTT's Avatar
I'm make believe
you typed all that and all you had to say is "also make sure the door is shut".
But that would be assumed in most cases
Old Feb 21, 2008 | 02:05 AM
auditech79's Avatar
The TT is the only car you have to have the door shut to program the one touch feature, the A4 and A6 can have the door open with no problems.
Old Feb 21, 2008 | 08:35 AM
Agnt008's Avatar
I'll give it a go... thank you very much. I dont' know what i would do without the people on this forum....
Old Feb 21, 2008 | 08:36 AM
Agnt008's Avatar
i'm pretty sure that's the blood code for mortal combat... i don't think even when i'm 80 yrs old i'll forget that ... ROFL
Old Feb 22, 2008 | 05:48 AM
DEDMN_TT's Avatar
ORIGINAL: cincyTT
Definitely a Contra code. Unless they used it in a different game... gots to be contra. Speaking of which, my windows do the same thing. The passenger side gets to 1/3 up then shoots back down. Is it the motor or is there something in the way?
Old Feb 22, 2008 | 07:20 AM
achTTung's Avatar
Up up down down left right left right B A start
Just because we use cheats doesn't mean we're not smart
Moldy Peaches - Anyone Else but You
Good song!
Old Feb 22, 2008 | 08:10 AM
diehlryan's Avatar
ORIGINAL: auditech79
could it be because the TTs windows drop .25inch when opened?
