P1128 Engine Code
Old Sep 15, 2008 | 01:02 PM
turbolove's Avatar
Member
Default P1128 Engine Code
How do i fix it???? Just got my car back for the tranny swap and new clutch only took a month in 2 days i drove around 359 miles it was fine then the check engine light came on ...
Old Sep 15, 2008 | 07:01 PM
erics01tt's Avatar
Smile Long term lean condition
Could be.......
MAF
O2 Sensors
Vacuum leak
Clogged fuel filter
To test the maf just unplug while running & if it gets better it is either bad or just dirty & you can clean it.
If you dont know when the fuel filter was changed last it probably needs changing.
To test for vacuum leaks or boost leaks a tool you can buy or just make yourself.
(what you need to make it)... a 3" fitting clean out adapter (see lowes or home dump) a shrader valve or air nipple.. a drill to make the hole in the clean out cap....and an air source to fill your system. (do a search for better more in depth directions)
Do you have a VAG & a laptop?
This should get you started & hopefully it helps you,
Eric
pwillaby
Jul 29, 2014 10:21 AM
mandito219
Jul 17, 2009 08:53 PM
Stouffer
Jun 28, 2008 02:16 PM
gksboi329
Feb 16, 2008 05:21 PM
co50
Feb 28, 2007 05:06 PM
