Please look this over for me!!
Old Dec 5, 2006 | 07:35 PM
mitchs_TT's Avatar
Default Please look this over for me!!
Well when Audi replaced my timing belt, they didn't install it correctly and it broke. So now they are responsible for fixing it. I have just recieved an email with the following items being fixed:
Part: 058109601C :VALVE (Intake valves)
Part: 058109611E :VALVE (Exhaust valves)
Part: 06B109119A :TOOTH BELT (timing belt)
Part: 06B109243D :ROLLER (timing belt tensioner)
Part: 037121687 :WASHER
Part: 058129717D :GASKET
Part: 06A253039E :GASKET
Part: 058198025A :GASKET SET
Part: 058103383M :GASKET
Part: 058198217 :GASKET SET
Part: 06A103385A :SCREW
Part: 06A103493BD :HOSE
Are there any other items that aren't listed that should be replaced as well? I just want to make sure I'm not going to run into anymore trouble with my car because of this.
Old Dec 5, 2006 | 08:00 PM
achTTung's Avatar
Default RE: Please look this over for me!!
did they just do the timing belt? If they didn't take care of the waterpump and thermostat, bitch at them until they do. Otherwise, that list looks complete to me.
Old Dec 5, 2006 | 08:07 PM
luvin_the_rings's Avatar
bug them about the water pump and thermostat
ask them about damage to the cams or valve springs
Old Dec 5, 2006 | 08:12 PM
mitchs_TT's Avatar
forgot to mention that the reason on why it went there to begin with was because of the water pump, so yes the water pump was changed... I'll have to ask about the thermostat.
Old Dec 5, 2006 | 08:37 PM
XCLR8TT's Avatar
Bent valves sound right. I would inquire about any damage to the pistons where they contacted the valves.
Old Dec 5, 2006 | 09:54 PM
achTTung's Avatar
i posted, and immediately tried to edit my post to mention water pump, etc.... something glitched and i couldn't view/change anything!XCLR8 picked up my slack. This man is a wealth of information! ; )
Old Dec 5, 2006 | 11:13 PM
MeanAudiA6's Avatar
looks ok to me per the water pump and thermostat. i could fax you my repair bill and it shows the complete list headgasket, etc i asked the mechanic about the springs and pistons and he said they are pretty strong and they didnt have and markings on them. i got all my intake valves replaced and 1 or 2 exhaust valves and all the gaskets as well make sure they fully flush the cooling system too!!
Old Dec 6, 2006 | 01:51 PM
rayveedub's Avatar
just curious, did they mention what was done incorrectly to cause the belt to snap?
Old Dec 6, 2006 | 01:55 PM
XCLR8TT's Avatar
ORIGINAL: rayveedub
Having the work done by the stealer?
Old Dec 6, 2006 | 02:12 PM
mitchs_TT's Avatar
ORIGINAL: rayveedub
Well, I had it towed to VW since it's only about 5 miles from my house when it broke... and they said the timing belt was torn to shreds. So they called Audi, which is about 65 miles away and they sent a tow truck to come pick up the car... I haven't seen it since... and that was Monday of last week.
