Poly Bushings
Old Dec 28, 2008 | 07:27 AM
dale55's Avatar
Default Poly Bushings
Anybody replace their control arm bushings with the poly ones from ECS? Just wondering if it is worth it.
dale
Old Dec 29, 2008 | 07:42 AM
keg225's Avatar
I have, and it seems to firm the front suspension. I also replaced the sway bar bushings w/ poly and replaced the strut top w/ new bearing and rubber, finally got the thumping and squeaking to stop.
Old Dec 29, 2008 | 05:04 PM
achTTung's Avatar
I have eccentric bushings on my rear arms, they're poly. Def. a firmer ride, better handling. I'd highly recommend either poly a-arm bushings, or the defcon sleeves, or both for the front. You'll see a HUGE difference in handling, and extended tire life since your car will hold its alignment in corners better, and not scrub against each other under load.
Theres a somewhat recent thread floating around for the defcon things.
b4 audi
Jan 29, 2008 09:54 PM
Artrip
Nov 1, 2007 08:58 PM
neur0tic
Apr 1, 2007 03:45 PM
a4r6
Mar 22, 2006 07:11 PM
nilla713
Jan 24, 2006 06:51 AM
