alright so its getting worse and worse... now its like loud and you can feel it.. if i just press in on the clutch nothing... but as soon as i engauge a gear its a loud pop. not like i high pitch thing though... sounds like someone knocking on a door... um and now i can feel it through the pedal.. but like i said only when i engauge. so i have noooooooooo clue whats going on but it sounds bad...
Only when you engage?
So step on clutch - clear
Put car into neutral - clear
Shift into gear - no bien... That's odd! Where are those handy dandy tech support guys?
RE: Popping noise when shifting
engine mounts anyone?... i remember runing out of ruber on one of the mounts on another 4 cyl car... but in this case you would be able to se the shifter moving inside the car... either up and down or back and forward...
Quote:
ORIGINAL: andrei
could be worth looking into. my car developed a knock when engaging a gear in 1st or 2nd and then again when you let off the gas with the car still in gear. It turned out the d/s engine/tranny mount went bad. replaced in less than 30mins and the part was ~ $180.ORIGINAL: andrei
I got my clutch/flywheel/starter installed for $250 + tax. - Got it done in a small town in IA. - Oddly he did a great job on the clutch/flywheel/starter - but put the power cables on backwards and couldn't get it to start. - What a fool. - HAHA. - He had to pay for that to be done at the dealer. - However what a SMOKING good deal.
- Got the timing belt/water pump installed for $190.00 at the same shop as well. - BLING.
ECS TUNING CLUTCH/FLYWHEEL / WATERPUMP/TIMING BELT
- BLING.
- BLING.
HEY ryan you have FWD big difference in labor cost...no transfer case to bring down with the tranny.
The dealers up here are a little more I think.... I was quoted 3100 for a clutch installed from the audi dealership. Some guys would do it for 650 but I dident trust there work. Rather have it done right.Plus he replaced both my cv shafts for a bonus while he had everything appart.
I got the stage 2+ for 1100 w Alum Fly wheel.
i have a loud clank noise when i release the clutch in 1st or 2nd gear. its annoying, should it be happening? i also have a loud pop noise when i through it in reverse and move maybe like 10 feet. something jus goes CRACK what could that be?
