Quick BOV ?
Old Aug 18, 2008 | 05:26 PM
Blue01TT's Avatar
Default Quick BOV ?
How do you know what bovs are closed at idle? Is there any certain thing to look for? I know hks are b/c thats mostly what everyone runs but i dont really want an hks. I seen a sard r2d2 bov online that sounded okay does anyone know anything about them?
Old Aug 18, 2008 | 05:45 PM
cincyTT's Avatar
I'm make believe
They are called twin piston type bov. HKS is a pull type but is also closed at idle. Dont think the SARD is a twin piston, but i can take a look at it real quick.
Old Aug 18, 2008 | 05:52 PM
cincyTT's Avatar
I'm make believe
The SARD is in FACT a twin piston according to this site and will work http://www.optionimports.com/r2d2.html jsut make sure you get a 25mm flange or find a way to get a 34mm to work
Old Aug 18, 2008 | 09:25 PM
theTTkid's Avatar
why not that 004?... and i like my hks
Old Aug 18, 2008 | 10:52 PM
Blue01TT's Avatar
as always cincy thanks for the help. but i do have one last question. after going on youtube and listening to some different bovs i think i want a greddy type s or rs is there any kinda of adapter flange i need to buy in order to make it work or will it simply bolt up?
Old Aug 19, 2008 | 12:05 AM
.clipse's Avatar
SoCal Crew Member
^ i've seen greddy type-s/rs on 1.8T's... just need that flange!
Old Aug 19, 2008 | 10:21 AM
cincyTT's Avatar
I'm make believe
You can get a 25mm flange for it. Those have been known to be hit or miss on some cars so if you get on, make sure you also get the 25mm recirc fitting if you need to recirc it.
Old Aug 19, 2008 | 12:34 PM
ooantipostoo's Avatar
Synapse is open at idle, but works great if it is recirculated. Its almost instant reaction going from boost to vacuum as it is a pull type system. We have 2 vacuum ports pulling the valve back and one boost only port on the side of the bov. So the valve has almost an instant reaction type to boost/vacuum. The one thing i've noticed with the bov is that it holds boost great in between gears.
Old Aug 19, 2008 | 12:44 PM
cincyTT's Avatar
I'm make believe
They make an antistall kit for that bov that will allow you to vent it.
Old Aug 19, 2008 | 12:47 PM
Yes we do, I prefer to recirculate.
