Radio Went Blank?
Old Nov 13, 2006 | 12:07 PM
bdonova's Avatar
Default Radio Went Blank?
The other day I went out to my 2000 audi tt and found the battery to be dead. Not surprised since it had been sitting i checked the battery and found it was bad. I went and replaced the battery and everything was fine. After replacing the battery I noticed that the radio and CD player did not work. There was no power to either one of them. I checked the fuse and it was fine. I dont know what could have cause the radio and CD player to go out. It does not even have power so that I can enter the safety code. I do not know if there is another fuse besides the one in the fuse panel. Any help would be greatly appreciated. Thank you
Old Nov 21, 2006 | 02:56 PM
markalopez's Avatar
Default RE: Radio Went Blank?
Same thing happened to me and dealer said to check side panel fuse (duh) and fuse on back of radio (both good). Shop is still investigating the problem. I'll keep you posted if they find a solution.
2001 TT Coupe, w/Bose Package
Old Nov 22, 2006 | 01:53 AM
TTsteve's Avatar
This has happened to me a few times and each time I took it in and they just took the radio out and basically put it back in and it worked. Make sure you have your radio code or they might charge you to look that up too.
heathyroz
Aug 1, 2011 06:26 PM
catman
Mar 29, 2008 04:18 PM
nanjil
Dec 22, 2007 04:41 PM
bdonova
Nov 13, 2006 12:08 PM
bdonova
Nov 13, 2006 01:59 AM
